where is stock amp??
28K views 8 replies 3 participants last post by  ahanix1989
#1 ·
I think I blew out the stock amp in my 06 Fusion SE. For the past year, I've been dealing with a blown speaker in the drivers side rear door. To remedy the problem, I bought new Infinity Kappa 682.9cf speakers for better sound/bumpage.
I installed the pass rear speaker - sounds perfect!
I installed the drivers rear speaker - no sound! :angry:
Since no soddering is required, I messed with the polarities and I can hear it getting POWER, but no connection.
So, where is the stock amp located? I think I may have either blown a channel in the amp or there is a bad connection in the wiring somewhere. If I can replace the stock amp for cheap, great! But I would rather avoid a whole new amp/speaker set up because that is time/patience/and money I dont have right now.
HELP!:grin:
Discussion starter · #5 ·
Mine has tweeters in the doors. I dont have the rear deck speakers.
It had the shitty 6-cd changer that locked up, which i eventually burned to the ground...literally.
I'll take a look at that diagram. If I dont have a factory amplifier, then I might be in some trouble...(hopefully I didnt blow a channel in my head unit)
