[quote author=hybrid driver link=topic=189421.msg3996199#msg3996199 date=1303067557]
The 1st printing is one I got from the same website last year and kept in my document file on the computer along with the 1st printing for my Hybrid. On the website, the Hybrid manuals still show 5.0 quarts for both years. Missprint too? Thanks for explaining the reason for the difference.
Hi hybrid. :wavey: I only researched the specific models we were discussing; non-hybrid 2010-2011 2.5 specs. So the information in my previous replies does not pertain to hybrid models.
Since you state that all printings of the Owners Manual specs for the 2010 and 2011 hybrids list 5.0 quart capacities (I am taking your word for it), then that would not be a misprint.
But in the end (again, just as an FYI for all of us), those Owners Manual specs are dry fill capacities, and simply dumping in a preset amount may wind up giving an overfill situation. The correct way to refill after an oil change is to carefully add the oil and check the fill level as you get closer to the specified fill capacity. In other words, just don't dump in 5.3 quarts, 5.0 quarts, 6.0 quarts etc. (or whatever is listed as the specific dry engine oil capacity) and call it a day. When approaching the specified fill capacity, slow down and check the dipstick for the proper fill level several times until the correct fill reading is reached on the dipstick. Then after running the vehicle a minute or so, let it sit for a few minutes, then check the oil level one more time. Again, this is to avoid an overfill (or underfill) condition.
Hopefully, this will help avoid confusion for other FFC members with similar questions.
Good luck. :cheers:
