2009 Ford Fusion, FWD I4, lowered on Tein S-Tech springs. I have an opportunity to buy 19 x 8.5 wheels with 45 offset, 245/40 tires. Will they fit?
According to this guide, the offset is too high with the wider wheels.
In addition, that guide does not take into consideration the effect of the lowering kit.
You really need to make your own measurements of the clearances of whatever tires you have on the vehicle and calculate the effect of the size differences of proposed new tires and wheels.
If you are really lucky, someone with an identical lowering kit might respond to your post.
Howdy! Where did you get your teins? I have a 2010 Lincoln MKZ and I'm going to be working on that shortly. Spring is on its way!
I have 18x8et44 rims that I test fit at stock height and the worked, but yours are going to be tough.
When shopping for parts I'm guessing that you look under Mazda 6 parts? What other cars share parts with us?
Thanks.
