Well.. I hooked up my Avic D3 a few weeks ago, now I am got my PAC SWI-PS steering wheel interface controller. I am going to hook everything up, but I cant figure out where the steering wheel control harness is.
Does anyone have any idea's or has anyone else attempted to do this w/ some tips for me?
I managed to finally get the avic d3 to dim, I tapped into one of the illumination wires that goto the onboard computer system.
there is no "steering wheel control harness"...
the steering wheel button [audio] wires are in the main stereo wiring harness (same harness as the power and speaker wires)
PIN 18 (grey/yellow) is the signal wire
PIN 19 (blue/white) is the return wire
I attached a text file of the stereo harness pin configuration to this post (it was originally an excel file, but you cant attach xls docs on this forum). that's where i got this info from (although I don't remember where I got it originally ;), if those pins/wires are not used after you installed your new head unit then you're probably good to go, but if you used them for something else then forget I ever posted this :))
[quote author=anarchyx link=topic=93544.msg1828341#msg1828341 date=1194041640]
What wire did you tapp into for the illumination for the dimmer?
