1 - 8 of 8 Posts
Hi everyone.
I'm trying to run some from the inside of my Fusion to the outside. For the life of me I can't find the spots that go through the firewall
Any help would be great thanks.
Sent from AutoGuide.com Free App
Kinda behind the battery. Look above your brake pedal from the inside, there's a slight cutout in the rubber insulator along the firewall.
I found the one behind the battery once I removed the battery. The one behind the break pedal I couldn't find. I think that it might have been the one above the clutch pedal. I got a coat hanger in the one above the clutch pedal but I couldn't find where it came out of. It was out of my sight. The one behind the battery is so filled with wires, it was hard to push anything in there. I know that the previous owner did for their remote start they added. I'm going to try again tomorrow.
There is one small ground wire coming through the grommet behind the battery. The hole is just big enough for that wire. Is there anywhere that I might be able to cut a small slit in the grommet where I'm not going to cut any wires? When I push on parts of the grommet there seems to be space above the wires. Does anyone know of I can cut or not?
Here's where mine came through on a 2010 AT.
http://imgur.com/5ZJjG6g
Behind the rubber is just some plastic. I used a decent size drill bit at a very low speed, then caulked around the wire.
I don't have the same plastic piece since that I drive a manual. Also I think yours in a generation after mine.
I'm kind of lost and not sure what to do. My buddy who is good with these things is being a pain and not helping me out. I might just run it off the stock horn, well, if I can find it.
1 - 8 of 8 Posts
