[quote author=Darin link=topic=86963.msg1658152#msg1658152 date=1187699452]
Whats the widest wheel you can fit on these cars? I would like to buy a set of 18x8.5 and don't want to regret it.
I guess the correct question is, will
a 18x8.5 wheel fit inside the fender and not rub on the suspension or body?
Hi Darin. :wavey: Please understand, I am only trying to be helpful, and am not trying to be a wiseguy. I cut and pasted your questions above. Your question was, "Will a 18X8.5 inch wheel fit inside the fender and not rub the suspension or body?" because you "would like to buy a set of 18X8.5 wheels and don't want to regret it."
I have answered twice before (now three times). Yes, an 18x8.5 inch wheel will fit and not rub the suspension or body, if it is the correct offset.
At least as far as "The Tire Rack", I can find no 9 inch wide wheel recommendations. So it would seem that 8.5 inches is your safe limit.
Again, if you go to "The Tire Rack", "Discount Tire", or any other major Wheel/Tire Retailer, you can select your vehicle Make and Model, and they will give you a long list of wheels which will fit. Many 18X8.5" recommendations are included. In briefly looking however, I could find no 9 inch recommendations. You don't have to buy from them if you don't want, just use the information.
I'm not sure how to answer your question any clearer.
One last thing Darin, as I would rather be safe than sorry. Just as an FYI, you do know that other than looks, an 18X8.5 inch wheel will cost you in every other department? It will adversely affect your acceleration and fuel mileage (unless you buy a very expensive, very lightweight wheel), your ride comfort and wallet. This is due to the higher unsprung weight mass of a larger wheel/tire combo If you are only doing it for the looks, go for it. Otherwise, I am not trying to talk you out of it, just warn you.
Good luck! :cheers:
PS - Really like your Ford logo! :shock:
