1 - 20 of 46 Posts
Does anyone else have this issue with there 4 cyl and manual tranny. Any time it is wet or there is snow on the ground it wheel hops so hard i think it is going to break an axle. Does anyone make motor mounts or inserts for the 2.3. i know that helped a lot on my neon autocross car and turbo daytona drag car.
Greetings...
We had a snow/ice storm in the nyc-area last night. This morning going to work traveling approx 45mph-50mph..I also had alot of wheel hop. Entering my work parking lot and parking, I noticed thick case of ICE ATTACHED INSIDE THE RIMs- Plus all other sterring/mechancial hardware underneath was full of ice.. Quick fix- a stick to knock it off or hot water...
good luck
Max.
[quote author=fusion9 link=topic=69562.msg1209402#msg1209402 date=1171556794]
Greetings...
good luck
Max.
Mine will do it anytime i accelarate to hard and the tires spin. Does not matter if it is cold out or not.
The post about wheel hop due to driving - just accelerate more slowly and you won't have issues. Don't race in rain/snow, etc.
Regarding the other post about wheel hop due to ice - I had the same issue this morning on my commute. Lots of ice gathered on the inside of the rims and threw the balance WAY off. I could barely hold the steering wheel at 60 mph. I took it to the self car wash at lunchtime and sprayed all that ice out of there - fixed the problem. :)
[quote author=Cueball link=topic=69562.msg1209574#msg1209574 date=1171560897]
i understand the wheels spinning if i hit it to hard but the wheel hop is so bad something is going to break and that is not right. i think the big thing is the motor mounts are just way to soft.
Nasty wheel hop here as well when accelerating into a turn from a dead stop. I have not noticed it turning right so far, only left. Yea it feels like something is going to get seriously f***ed up under there.
I have lots of wheel hop in any condition...but when the tires are wet, it is horrible. I love some of this great advice...don't race in the rain! :sarc: :bitching:
I have the i4 auto and have never had any wheelhop, wet or drop(haven't drivin in ice yet). the auto deliver smooth power transfer and a constant spin, even turning left or right while they spin. I've done a little parking lot adventures and never any problem. I think this might be a manual problem, maybe the clutch is grabby from the cold????
[quote author=mtl1977 link=topic=69562.msg1210846#msg1210846 date=1171588831]
Well, my other advice would be to learn to drive a stick! Contour SVT's have a lot of wheel hop too under hard acceleration - many blown differential at drag strips, etc. I never had any problems with mine.
[quote author=Cueball link=topic=69562.msg1211540#msg1211540 date=1171633465]
learn to drive stick :lol: Maybe you should check out some of my SCCA championships in HS, GS, DSP, and FM all of which are 5 speeds but the FM and that is a Formula 440 so there is no gear box. I have been racing for many many years. Drag as well as Autocrossing and Road racing. I think i know how to drive a stick.
:D :D :D Yes, I am well aware of this. My dad told me about it...he blew a few MTX75s up himself (M-plate cars).
[quote author=slaterracing link=topic=69562.msg1211563#msg1211563 date=1171634902]
I'm not trying to start a fight. The Fusion is not a race car. It's a fwd (or awd) 4 door grocery getter. It wasn't designed to be driven like a race car. That's why you get some wheel hop.
Discussion Starter · #16 ·
[quote author=Cueball link=topic=69562.msg1211874#msg1211874 date=1171643394]
I do not race the car and will not as i have my mustang and my F440 for that. But when i am pulling out into traffic and the wheel feels like it is going to go thru the fender there is an issue with it. The motor mounts are way to soft.
Yes I have this trouble too.
It does not just happen when accelerating hard or "racing" in the rain. I experience when I am trying to drive up a hill in the snow and ice under normal and slow acceleration.
Normally I will get the wheel hop when pulling out of somewhere in the rain, but this straight-line snow thing is annoying.
I had this same problem with my Focus, but never with any of my Honda Accords or Toyota Camry's that were manuals.
Don't make absurd comments if you want to avoid a fight...not designed as a race car...so that is why there is wheel hop? Did you quote this from a vehicle dynamics book? Or did I miss something in my physics classes? :rofl:
My 1993 Escort Wagon was definitely not designed as a race car. And the wheels never hopped. In fact, I could smoke the tires on 88 hp and 108 ft-lbs at 163k miles.
The hop issue is related to tire compound, bushings and suspension geometry.
Greetings: S/R
I've driven stick for 20-plus years. Porsche 911T and my Ford Probe GT. Both were modified.
Personally, if I was in your situation I would bring it back to the dealer a.s.a.p. This sounds bad.
Something must be broken or wacked. It does happen. Demand it....
good luck.
Max.
Discussion Starter · #20 ·
[quote author=fusion9 link=topic=69562.msg1212554#msg1212554 date=1171660015]
Greetings: S/R
good luck.
Max.
i am sure they are not going to do anything i think it is just the way the front end is set up. just called and made an apt for monday morning. Will see what they say
1 - 20 of 46 Posts
