okay im getting wheels for my car and also a lowering kit...probably the eibach pro kit. but im just wondering first off if 20's will fit with the lowering kit...and im wondering whats the max width i can get 20x8.5 or 20x9? and also im wondering if im lowering it and getting 20s should i get the 245/30/20 or go with the 35?
Ive got 20's, it all depends on the actual rim size, if its between like +35 - +45 offset You should get away with 35s. I had 35s and they rubbed slightly and alot of rubbing on the rear when going over bumps had to downsize to 30 series. Hope that helped. Have had all kinds of problems with a 30 on a 20" rim, dings bends, cuts in the sidewall. Getting my rims replaced by the dealership to accomodate 35 series tire.
