Hi
I need to replace my 2016 underbody guards , but i don't know the of the parts i want to replace the Green , purple and lime color parts , the Green is the engine mud guard, i just need the names of the purple and the lime colored
thanks
Line Font Parallel Slope Art
· Administrator
Hi
thanks
Hi jim and welcome to the Ford Fusion Club. The part numbers are what you need.They are all called some version of under-body shields, splash guards, etc. That site has reference numbers for most of the parts and fasteners in that exploded diagram, but not all are numbered.
In addition, while they may simply be using a generic vehicle depiction, the vehicle shown in that diagram is obviously not a Fusion. So make sure you are looking at the correct parts diagram for a Fusion before purchasing anything.
In my opinion, it would be best to stop by the Parts Department of your local Ford Dealer and ask them for the part numbers (and a price). Then you can negotiate price with them, or take the part numbers to purchase online. Have your VIN handy, as that is how they cross reference the correct part numbers.
2012 Fusion Sport AWD
That looks like the 2017-2019 Escape diagram, so things will not be the same.
Those 11782 panels along the cabin are called "Air Deflector" and depends on your engine, drive train, as to what the part numbers are. Drivers side non AWD is probably DG9Z-9911782-F
If you have the 2.0, that metal panel after the engine shield (purple) is called a Rear Deflector, DG9Z-6P013-D
I wouldn't order them by part number, just giving you examples of what I think you are after. I don't remember the metal deflector on my 2015 with the 2.5.
Thanks a lot :D
Thank you very much , you hit the target like a sniper (y)(y)(y)
