http://us.f13.yahoofs.com/bc/43dafb42mc9a58637/bc/Fusion+TSB+PDF+Files/tsb07-01-03+(Power+Steering+Leak).pdf?BCLrkZGBz4khmSft
FORD: 2006 Fusion
LINCOLN: 2006 Zephyr
MERCURY: 2006 Milan
ISSUE:
Some 2006 Fusion, Milan and Zephyr vehicles built before 8/2/2006 may exhibit a small power steering fluid leak at the line attachment areas of the rack or the pump.
ACTION:
SERVICE PROCEDURE
Replace the banjo bolt and the two (2) sealing washers following Workshop Manual, Section 211-02 using the service kit.
One (1) kit is used for one (1) joint (either pump or gear).
Joint must be torqued with a hand torque wrench to 35 lb-ft (47 N-m) for pumps, 41 lb-ft (55 N-m) for gears. This new banjo bolt has a higher torque rating to achieve a higher clamp load.
FORD: 2006 Fusion
MERCURY: 2006 Milan
ISSUE:
ACTION:
SERVICE PROCEDURE
