I have a 07 Fusion I4 that I intend to tow a ATV with.
Anyone doing any towing with their Fusion?
I know that Ford does not at this time rate the Fusion for towing, so no reason to ride that horse!
Maybe 1100lbs at most!
auto or manual? If you are running an auto then you need a trans cooler no mater what. Also if you have ever pulled anything with a car that has overdrive you will know but i will say it anyway do not tow in OD. make sure you stay in drive only. If you have an manual you would have no issues. i pulled a trailer with my neon all the time with race tires and tools in it. with teh trailer, tires, tools, jack and all that stuff i was in the 1K # range and had no issue running 70 on the freeway. The neon only had 150hp stock the fusion has a little more push i has a lot more tq to get off the line.
