[quote author=jmmilan link=topic=202461.msg4176179#msg4176179 date=1327091847]
Tire Pressue Sensor Fault!!! Gotta go to the the tire shop and get it check out now, I was getting new tires anyways. I'm hoping one of the TPMS just need retraining?
Before you do that, go to your local gas station and check the pressure in your tires...this isn't something you would normally, if ever need a specialist to look at.
[quote author=CuseFusion link=topic=202461.msg4176229#msg4176229 date=1327102430]
Yeah, the first thing I did was I took them to the gas station to check the pressure. Pressure in all four was 38 psi. Anyways if my pressure was low the dashboard would have said low pressure, not tire pressure sensor fault.
[/QUOTE]
I am having the same problem with my 2010 Fusion SEL. I put 32 PSI in all the tires and the error message still won't go away. What are my options?
