ya, but tirerack is too expensive.. they used to be pretty decent, but are full of themselves now and charge over what rims are worth...
Another thing to consider is the hub bore on the rim. You may have the correct offset & bolt pattern but if the bore is too small, the rim won't fit. If it's loo large, the rim will not be stable. A lot of rims require a centering ring for proper installation.
