2012 SEL 2.5
2012 SEL At one time my phone was sync to the car. I lost the connection.
Now phone will not sync to the car. I have read everything and watch videos all with no connection.
What can I do?
What can I do?
Hi ffj. If you have not tried these things already: Delete all phones from your SYNC list. Then perform a SYNC reset, following the instructions from the Owners Manual. Then try re-pairing.
If that does not work, try disconnecting the battery in your car for at least 10 minutes, then try re-pairing.
Also, did this problem suddenly occur with your old phone that worked previously, or did it start with a new phone?
2012 SEL 2.5
I unhooked the battery this morning but only for 3 or 4 minutes. Did no good.
It's the same phone that's been sync for some time. I will try to delete all phones from the system next.
Tks
2012 SEL 2.5
I found the best way to get sync back is.
To pull the number 13 fuse and put it back in.
Then clear all settings and start over.
