61 - 70 of 70 Posts
[quote author=20louie06 link=topic=50227.msg3671392#msg3671392 date=1274791204]
Mustang center bore is 70.5mm.
That's pretty close. Is a ring available for that small of a gap?
Premium Member
Yep there sure is. I'm 90% sure that those are the ones I'm using. Not completely sure though.
Anyways here's a link https://1010tires.com/hubrings.asp
You would have to use the 67.1 inside and 70 outside diameter. You would have about a 3/32" gap around. However you should keep looking for the exact one you need.
I found the exact one you need but I wouldn't pay $100 for them. It might come down to going to your local tire shop and see if they can order them for you.
[quote author=ELIM link=topic=50227.msg3675074#msg3675074 date=1274986459]
Does anyone know what style 18" wheels will come with the 2011 SAP package?
Hi ELIM. :wavey: The 2011 Fusion Order Guide (see page 15 of the attachment on the first post here: www.fordfusionclub.com/index.php?topic=173018.0) does not yet list wheel images for the SAP or Luxury packages. So at least to my knowledge, it is still not publicly known.
If any further information comes up, I (or someone else) will certainly post back.
Good luck. :cheers:
[quote author=bbf2530 link=topic=50227.msg3675096#msg3675096 date=1274987501]
Good luck. :cheers:
Thanks. I can't find it anywhere as I did look thru that guide too.
I'm thinking of upgrading my 2011 order but want the same styled wheels as the current 2010 SAP package. :)
[quote author=ELIM link=topic=50227.msg3675116#msg3675116 date=1274988250]
Good luck. :cheers:
Hi ELIM. :wavey: Have you checked with the Dealer. They should have the latest information (if they are competent). :shock:
Let us know what you find out.
Good luck. :cheers:
[quote author=bbf2530 link=topic=50227.msg3675125#msg3675125 date=1274988692]
Good luck. :cheers:
Good luck. :cheers:
NO change on the SAP wheels for 2011!! :koolaid: :goodjob:
Local dealer had to double-check but confirmed it (President Award's winner so not too incompetent :lol:).
Just in case anyone wanted to know, since I didn't see it anywhere on here, the 2010 steel wheels w/hup caps are 17x7.5 +44
I hope this hasnt been answered I checked. Does any tech have access to the information about stock clearance for our cars w/ the stock rims (inside rim to the suspension parts) This would help everyone greatly in using the 1010 website.
Thank you
alf
I have some updated information.
I have 18x8 +42 wheels these are the clearances on the inside
I'm in the process of looking into 18x9.5 which based on my measurements will work w/ very little poke past the rear panel about 6mm. Hopefully this info will be use full for your project
18x8 +42
Rear is not an issue
clearance to the swing arm is 43mm
Front a bit of a different story
clearance to the spindle upper arm is
19mm
61 - 70 of 70 Posts
