Last night I installed the TWM shifter bushing kit. Don't waste your money. There is very little diffrence, if any. While the install was quite easy, the bushings are NOT a perfect fit as expected. There is still alot of slop in the shifter. I do plan on installing the short shifter as soon as it is available. (currently out of stock)
If you are planning on installing the shifter, you might as well install the bushings bucause you have to remove the assembly. But if you just planning on installing the bushings, don't bother.
Please remember that this is my opinion!
