Anybody considering changing their shift cable with a high-degree of technical knowledge or AC tools should think twice. The entire process takes about 12 hours from start to finish with one person, being careful.
Steps:
1.) Remove front seats (this should set the tone for the entire job... prepare yourself)
2.) Remove console (knob, cover, 6 screws holding base in)
3.) Strip dash (pillars, kicks, glove box and cluster)
4.) Remove Column (remove 4 bolts on trim [one is torx] and 4 nuts holding column to underside of dash)
5.) Remove Dash (various 10mm bolts)
6.) Unhook and drain heater core (self-adjusting factory hose clamps)
7.) Recover R134-A from AC system (you've got the equipment, right? Doesn't everybody?)
8.) Disconnect AC condensor line block (10mm bolt)
9.) Remove heater box assy (10mm nuts on firewall studs)
10.) Pop retainers loose on rear-zone ducting on the console hump at the front
11.) Remove airbag control module (3 10mm bolts)
12.) Remove firewall insulation (10mm plastic retainers on firewall studs)
13.) Unclip cables from shifter (if they aren't broken loose already like mine)
14.) Remove 10mm nut on holder keeping cables away from manifold under hood
15.) Unclip cables from trans and linkage bracket
16.) Remove 2 10mm nuts from firewall plate on shift cable
17.) Feed shift cable through to the inside of the car
And... my favorite FSM caveat...
18.) Installation is reverse of removal...
I didn't want to evacuate the AC system since I'd just vacuumed it down and recharged it last year when I bought the car, so I put a bottle jack in the car on the pass side and used it to lift the assembly slightly with a block of wood. I didn't put stress on the condenser block.
Then, I used a utility knife to slit the sound-deadening on each side to get to the cable. Don't worry, this is only for sound-deadening, the heat insulation is under the hood between the engine and firewall.
Lastly, if you opt for this method... be prepared to get cut, scratched, and scraped while dealing with positioning the cable ends to come out and go back in. It really takes less time to disconnect everything, but it can be done without. With enough beer, you can accomplish anything.
just for reference, here in Indy, I had one dealer who quoted me $950 as a bare minimum in labor (I bought the cable months ago) to change it and another who quoted $1274 (parts not included).
I no longer have any love or even like for my fusion. Designing a car where common wear items cannot be changed without extensive amounts of labor is dishonest. If you think I'm jumping the gun on this one, look at the procedure for changing the clutch master cylinder. Disconnecting and bleeding the entire brake system should NOT be necessary for a job like this unless you're trying to increase revenue from repairs by increasing the amount of labor.
