1 - 10 of 10 Posts
Anybody having an issue with rust forming on the chrome lugnuts?
I have had my Milan since November of 2005 and recently the lugnuts started to show rust.
Thoughts?
I'd go back to the dealer & ask nicely for some new replacements, let them see the bad / rusty ones you have on now. Tell them you'll install them yourself, just want some replacements. Should be no problem. Sounds like the protective plastic casing got cracked during factory ( have you / anyone ever removed your wheels since
getting her ? ) install.
I have had them off/on several times for tire rotation.
I sure that has added to the problem, but it shouldn't be that bad after 1 1/2 years.
I agree with you, very little wear on them, they should last & not be damaged from that stuff. Go to Ford & see if they'll give you some new ones, they should.
I don't see how they would call this a "wear & tear item', like tires, wiper blades etc., they should replace them under warrenty, plus the're FREAKIN' cheap !!! Not like you want a new headlight assembly because it has a rock chip in it
I had my wheels off yesterday for cleaning and noticed a little rust on a few of them. Nothing serious though, at least not yet.
When cleanning mine i noticed that I have rust on a few of them as well. I'd imagine that if they are rusting ti would be covered under the corrosion warranty.
All lugnuts replaced under warranty.
Wow, that's cool. I'm going to have to call my dealer because the lug nuts on both my rear wheels are rusting. I had to replace both rear tires already, one from the dealer due to "manufacturer defect" and one because I got a huge nail in the sidewall. Then last week when I pulled the rear wheels off to install the splash guards, I noticed they were starting to rust. They have a chrome cover over the actual nut and it must distort and crack the chrome when you torque on them. Anyway, they shouldn't be rusting after only a month, especially in the middle of the bone dry desert.
1 - 10 of 10 Posts
