Good afternoon,
My outer rocker panels were rusting so I cut them off to replace them with new ones. I found a huge rust hole in the member behind the rocker panel at the passenger side rear corner. I apologize for my ignorance but I am not sure what the member is, is it the frame (hoping not)? Tire Automotive tire Motor vehicle Tread Bumper Automotive tire Motor vehicle Wood Bumper Automotive exterior Automotive tire Hood Automotive lighting Motor vehicle Wood If so, can it be repaired or do I need to junk my 2011 Fusion? Images attached.
Good afternoon,
My outer rocker panels were rusting so I cut them off to replace them with new ones. I found a huge rust hole in the member behind the rocker panel at the passenger side rear corner. I apologize for my ignorance but I am not sure what the member is, is it the frame (hoping not)? View attachment 105637 View attachment 105638 View attachment 105639 If so, can it be repaired or do I need to junk my 2011 Fusion? Images attached.
Just wondering, where do you live ?
