[quote author=Nr9 link=topic=89855.msg1733863#msg1733863 date=1190598962]
is it normal for the V6 to have the right exhaust tip lower than the left one?
Hi Nr9. :wavey: No, not normal. There should not be much of a difference in fit between the two. If there is more than a fraction of an inch or so, it would seem that one of your exhaust tips is either loose or bent.
Check the hangers and connections to see if you can find a problem.
Good luck! :cheers:
