1 - 16 of 16 Posts
The AM stations work for about 5 min when i start my car then they shut off and its just static anyone know what this is?
the fm stations work fine though? If the fm stations do the same as your am you may have a lose or weak connection with your antenna.
yup... there might a defect in your radio then... It seems wierd that all your AM stations would get static after 5 minutes of working fine. Everything is all stock too? You havent changed or modified anything?
that could be the problem.
1st) what is it? how is it hooked up? does it require special settings?
2nd) try unhooking it and see if everything works ok. if it does you narrowed your problem to the "one of them things for my ipod"
If it's not the input adapter (for the iPod), it could be the antenna booster.
It should be violet/black. However, colors can change. It would be in pin location #5. See my attachment.
Again, the lack of correct spelling and punctuation astounds me. Have the time on this board I can't even understand what someone is trying to say.
....I think he meant to say... Half the time.
Well I don't know about newyork, but all the sports radio here in South Jersey is on AM. So I do listen to it quite a bit.
1 - 16 of 16 Posts
