1 - 14 of 14 Posts
Has anyone else had one of the nuts pop off the shackles that hold the rear sway bar on?
When I had the RB rear sway bar put on it popped the nut off the driver side shackle after a day or 2.
I ordered a pair of shackles and nuts (from Ford) and had it replaced at a client's auto shop (the one that put the sway bar in originally) and now a few months later the nut popped off again. I watched them replace it and they used loc-tite and made sure it was tightened correctly.
In comparison to the stock sway bar, where it mounts to the shackle is considerably thicker and I am wondering if it has to do with it falling off. When the nut is tightened the threads stick out 1 or 2 past the plastic log on the nut.
I am just about to have the stock sway bar put back on and not worry about it anymore. I just thought I would give it a shot on the forum and see if anyone has any experience with this happening or how to make it stay on.
Thanks in advance!!!
I think this is a pretty common problem with this bar on the Mazda 6. Swing over to those forums and read up on some of the solutions.
[quote author=WiKDMoNKY link=topic=79565.msg1462034#msg1462034 date=1181024971]
Hi
You will need this: http://www.racingbeat.com/FRmazda6.htm
[quote author=Blackbet link=topic=79565.msg1462333#msg1462333 date=1181048074]
Hi
Need what, that is a link to the Mazda 6 parts page on Racing Beat's website.
I already have the Racing Beat 27mm rear sway bar.
Are you saying I need the springs too???
[quote author=Waldo link=topic=79565.msg1462247#msg1462247 date=1181043700]
I just went to the Mazda 6 forums and there is a whopping 4 posts under the Mazda 6/Supsension forum.
Do you have a direct link as to where I should look?
[quote author=WiKDMoNKY link=topic=79565.msg1462671#msg1462671 date=1181055627]
Hi
Hi,
I try to give you a direct link but doesn't work. It takes you to the home page.
When you go to the page select in the select category, suspension. Than click
on the Mazda 6 Sway Bar Endlinks - Rear and you should see it.
MoNKY, thanks. I'm going to order one of the Racing Beat sway bars but I was holding off after reading your post. I guess I'll have to get the end links too.
have they helped you any ?
So this is going to be a stupid question; but does both the front/rear sway bars from Racing Beat; bolt right on to the Fusion??
the rear does...but you'll have to buy these endlinks eventually....
the front, not 100% sure
No wonder, I thought it was me doing a half-a!# job installing the things. I've replaced endlinks once already on the passenger side (I was just about to order another). Hmmm, I guess I need to order these then. Thanks for the heads up guys!
1 - 14 of 14 Posts
