Pictures of a 06 Fusion with the whole HID set up (fog lights included)
7183 Views 20 Replies 9 Participants Last post by  davidchiez
16
Most of you guys have been asking about the HID's on the fog lights. So I took the pictures at my mother in Laws house since my wife had the camera there.  The picture quality might sucked.  The camara wasnt fully charged and it was ready to die.
[glow=red,2,300]Fog lights with the 12000k McCulloch set up.(Notice the cut off, blue to purple)[/glow]
[glow=red,2,300] Cut off pics[/glow]
(Blue)
(Purple)
[glow=red,2,300]Low beam headlights with the 6000k McCulloch set up[/glow].
Warming up when you first turn it on.
Both lights turned on
[glow=red,2,300]This is what happens when you aim them at least an inch up. (It will blind the incoming drivers)[/glow]
[glow=red,2,300][/glow]
1 - 20 of 21 Posts
That's awesome! Makes me want to do that!
the fog and low beams are h11.. but some HID site mention special h11fog light bulbs??? whats all that about? or can u just get 2 sets of h11 and call it a day?
Yea, they both use the same H11 set up. Same lock patern, and same bulb. There is no difference. What sie said about the H11 foglights?
i just got the same setup as you... did u use a wiring harness? and can u explain a little on how to get access to the fog lights... i dont see a way or opening to access them from top or bottom...
any way u can chime in on how to aim the headlights?
[quote author=mundy link=topic=56995.msg1048404#msg1048404 date=1162527681]
RTFM :)
RTFM i guess means "read the Forums MAN" or "Read the Freaken Manuel" ??? which one is it?
oh yeah the fog light access... where did u mout ballast for the fogs?
[quote author=mundy link=topic=56995.msg1050034#msg1050034 date=1162596500]
RTFM i guess means "Read the Freaken Manuel" ???
BINGO! :lol:
thanks... i knew id get help from this forum... just found the page "48" too funny...
Same here... got 8000K GP Thunder in both low beams and fog lights...
They way you can get to your fog lights are by under the car.  You will need to unbolt the plastic that is under the car.  Basiclly if you look under your car by each tire, you will see 4 mini bolts.  The plastic has a circular hole to drain the water out.  That is the peace you have to remove to get to your fog lights.
Once you have both sides out of your way,  just swap the bulbs and you will want to mount the ballast where water cant get to and will get a good cool breeze of hair.  Most common is always next to your fog lights by where the actuall projecters mount.  Dont use the sticky pads they provide, because the heat and moisture will knock it off.  Use two small screws and find a good secure place.
Once you install the lights to the projectors, you wont need to aim them.   But as for the headlights, always go with OEM Specs or at least to where you are most cool with and away from other drivers eyes.
I spoke with the Service manager today, he told me that if they see an HID set up on our cars, the warranty wouldnt be voided on our light components, but it will be voided if the sockets got burned or the light system fried up due to the "HID" system, then we are on our own and a money comes out of our pockets to replace a $1000 light components and wiring.
But hoping nothing happens to none of us, if it does happen, just never mention an HID system on your car and just go ahead and pull out your HID kit from your car, put the original halogen lights back in your car and drive to the dealer. And act like you dont know whats going on.
But the dealer will Aim our HID lights in our lamps to a good spec for $25.  Which is not bad since they have all the tools and machines required to aim these lights.
i just finish installing low/fogs with 6000k when they fire up they bright as hell.. but them dim.. not sure if that sopose to happen.. allso the fogs upper part of the beam showing a rainbow effect.. and seem dimmer then the lows...
im just glad everything turns on...
any chance u saw or know how to aim? is it a bolt u turn for up and down? my beam pattern is like all going downword... i would like to higher it a bit.. but not to the piont of blinding people...
i looked in the manuel but i cant find anything..
[quote author=mundy link=topic=56995.msg1051827#msg1051827 date=1162712993]
You musta not looked very hard. :shock:
In my "FORD FUSION OWNER'S GUIDE 2006" in the Index under "headlamps" subcatagory "aiming" it say pages 37-38.  On those pages it describes how to adjust the verticle aim using the "verticle adjuster".  There is no horizontal adjustment on our headlights.
You musta had somebody install your HIDs for you.  I can't see somebody doing this themselves and then can't find how to aim them in the owners manual.  It's not like it's hidden or anything.  Took all of 10 seconds to find.
thanks i can see why i missed that my manuel got wet and have some pages stuck together..... but i guess i'll see ebay for a new one...
and i did install them myself... cut up finger from slicing dust cap, and minor cuts and bruses from small opening and trying to tie rap eeything... plus one fog lhad a bigger tab, had to shave a bit off..
forums all bout help.... now it documented so the next person that uses sreach will find it....
flame me ok but at least it will help some-1 eles =)
I'm blind now 8)
Yea what gives. We are here to help out each other and keep each other posted with new things. We are not here to bash on no one and to bash on some one for nothing. Every one makes mistakes, no one is perfect.
Anyways, if you want to aim them to best view, just take it to Ford. Its only about $25. Trust me, you will love the results when they aim those suckers.
And as for the fog lights been dimmed, do you have 6000k on fog lights and headlights? Because I know the 6000k are very bright, even on the fog lights.
just seems the low beams are brighter.. i think maybe becuz somehow they are all aim downword, i figured the hid light would be all over the place but it mostly concentrate in the lower fog light beam area.. for now im good.. not stressing it much... i will tinker with aim and put them up a tad.. all trial and error..
[quote author=mundy link=topic=56995.msg1058177#msg1058177 date=1163026923]
Just take it to a dealer to aim - and give those poor cut-up and bruised fingers some rest!
Yea I agree with fused1. Just drop it off to the dealer, sit down and relax, and treat your self for a nice cold beer and enjoy the rest of the day.
Where's the best place to get HID lighting kits? I've been wanting to do the same, and those pics show exactly what I've been looking for. Also, Are they legal in the US? Not sure where to look to find out....
EDIT: I'm retarded. Right in front of my face. :?
1 - 20 of 21 Posts
