Link Reinforcement Panel $125.10
BUY NOW
This GTSpec link reinforcement panel mount is designed to stiffen up your chassis and help reduce vehicle body flex. When making excessive corners, you will want to reduce the chassis flex and increase the rigidity of your car. GTSpec has designed these braces to be fully functional in conjunction with their other other body braces.
Only available in GTSpec blue/grey
Rear V Brace $161.10
BUY NOW
The GTSpec rear V-Brace uses the factory reinforcement panel and also to the GTSpec reinforcement panel to provide reduced flexing in the rear of the chassis. Compatible with MazdaSpeed3 and Mazda3.
Only available in GTSpec blue/grey.
4 Point Ladder Brace $166.50
BUY NOW
The GTSpec 4-point ladder brace replaces the factory subframe brace. Stiffens up the front of the chassis and also removes a few pounds of weight from the front end. Great addition for better cornering.
Mid Chassis Brace $144.90
BUY NOW
The GTSpec mid chassis brace is a direct replacement for the stock mid chassis brace. Works great in conjunction with the other GTSpec under body braces. Direct bolt on to stock mounting holes. Made in 6061 air craft grade aluminum.
4 Point Brace $125.10
BUY NOW
The GTSpec 4-point mid brace mounts directly behind the 4 point ladder brace replacing the factory piece. Works great in conjuction with the 4 point ladder brace and eliminates a pound or so of weight from the front end.
BUY NOW
BUY NOW
BUY NOW
BUY NOW
BUY NOW
