[quote author=TastyMilan link=topic=87655.msg1677092#msg1677092 date=1188401820]
ya i checked thos nothing is listed for gauge cluster nor did i see a busted one. it was early this am but ill look again seeing if someone knew specifics is all.
Hi Tasty. :wavey: Try looking at the Owners Manual again. I have an MKZ, so am not sure if the fuses are exactly the same, but in the MKZ the "Cluster" fuses are listed as "Passenger Compartment Fuse Box" #13, #23, #27.
Take a closer look, I am pretty sure they will be listed.
Good luck! :cheers:
EDIT - Cisco got there before I did! Just to add to Cisco's answer. Even if you find a/the fried fuse, I would still make a Dealer appointment. Cars don't normally heal themselves, so it probably will reoccur. Replace the fuse temporarily, but then put the burnt fuse back in place when you bring it in. Let the Dealer check for the underlying problem. It is not normal to have fuses blow, so there is some unknown problem with your vehicle electrical system. Better to have it checked now, and while still under warranty
