Well the single 12" Eclipse sub was great, but like most young people, I needed more.
So here they are - 2 12" Rockford P3's powered by 1000 Watt Rockford Amp. Holy hell this thing bumps.
These P3's are amazing, if your looking for awsome bass I highly recommend these, I was and still am very impressed. With my last sub at volume 20 on my cd player it was rattling me ears, if I turn to volume to 15 with these, it actually hurts my ears, lol.
Where'd you run the amp wire? Did you run it through the interior, and drill a hole outward to the firewall?
Also, where'd you run your amp ground, if you could take some pics of those 2 it would rock!
Overall, the subs look nice.. great job.
Thanks Anarchyx,
The amp is mounted on the backside of the rear seat. The wires run under the seat, under the carpet then through the firewall. As for the ground, if you lift the trunk mat, right behind the seat they drilled a small bolt to the frame. With the wire between of course. I will try and get some pics tomarrow.
