21 - 40 of 41 Posts
Those looks amazing! I think I'm going to have to go back to the drawing board for a wheel / tire package.
+30 or +25 is the way I'm going to go in an 8.5". Or +35 or +30 in a 9".
I'm right there with ya dude. I have NO idea what I want to get for my car. A part of me wants to leave it stock, and trade it in for a V6 down the road... or just leave it as a DD, and buy another car. Maybe a Mazdaspeed3 or mazdaspeedprotege... mm
Discussion Starter · #23 ·
Car looks really good overall though. Good job.
Thanks Talisman, that means a lot coming from you!
I don't know what you're talking about I think you car looks great with the xxr's! I always thought yours was one of the nicest in the forum. Either way though I'm sure whatever you do it will look dope. +30 on an 8.5" is indeed perfect on our cars.
Hmmm possibly selling the xxrs huh? You might have a buyer.
The car looks great btw. Nice drop nice fitment. Great job.
Thank you, it was a lot of work getting it right.
I got the height dialed in but I'm having a slight issue. Even though the rear coilovers are set to the exact same height, the passenger side is 1/2" higher than the drivers side. I took it all apart again and double checked that the springs and perches were seated correctly and everything is tight, but it didn't fix it. Anybody else encounter this?
Other than that I don't think I could get it anymore perfect. I'm very happy with the results. Thanks to everyone that gave advice along the way!:grin:
Dude, I have the exact same issue. It's usually between 1/4 and 3/4 inch higher on the passenger side. My rear coils are bottomed out, both at max low.
If you figure it out, let me know.
Discussion Starter · #28 ·
Thanks for the info! That makes me think that there its probably an issue with how the car is balanced; maybe there's more weight on the drivers side? In that case I think I'll just lower my passenger side to match.
What coils do you have? I have ST's and I could still go about another inch lower.
I'm on ST's. The rear really doesn't go low enough for my liking. I've got about 1/2 inch of rake. My fronts have 3-4 threads left and the rears are bottomed out at max low. Here's the final stance for this season:
IMG_3408_wm by Lyonsroar91, on Flickr
You can see the back pretty good in this picture:
IMG_3769_wm by Lyonsroar91, on Flickr
Next season I'll be taking the rear upper spring perch out for maximum low. :grin:
Discussion Starter · #31 ·
So an interesting turn of events today. I measured my heights again after work and now the back is almost even but the front got off by 1/4". I'm thinking maybe its the gas tank. When I first measured it my tank was completely full. After driving for a combined hour and 1/2 it changed. Do you know how full your tank was when you measured?
nice howcome you didnt go with 40 series? ohh yeah what brand are those wheels?
I wanted to get a mild stretch on the tire while still maintaining the same overall diameter of my original 17's. 225/45/18 is only .1" bigger than the original 225/50/17 while giving me a mild stretch on an 8.5 wheel. I could have gone with a 235/40/18 which would have also gave me roughly the same diameter, but then the tire would stick out over the lip of the wheel. In other words, I would not have any stretch, which makes it harder to lower the car without rubbing; not to mention I don't like how that looks.
I found this website gives you a pretty accurate idea of how the tire will sit over the wheel if you need to figure it out in the future:
http://www.jonathanrowny.com/page/offset-calculator
I got the wheels from wagen-wheels.com, they are their WW1 model. They're really just some cheap BBS LM replicas. I've always loved the LM's but could never justify spending $4000 on a set of wheels. The WW1's were the only LM reps I found that come in our bolt pattern, with the +30 offset, and all silver. Privat has some decent LM reps in our size but they only sell them with a grey center, which I didn't want. Plus from my VW days I knew that the WW1's were a decent wheel.
Thats surprising. it could be that you're running 19's or maybe its a difference between the 1st and 2nd gens? I'm tucking a little bit of tire in the rear as I am right now but I can clearly see a little wheel gap with yours. I think taking out your perches will set you right though; I have a feeling your car will look even better when you get lower on those wheels. I still think you should blackout your headlights though :winker:
Discussion Starter · #33 ·
I know the ground level has a lot of effect on heights as well. When my gas tank is full they are more even, but still not 100%. It's annoying.
Every time I've measured I've been in my garage so I know the floor is level. I agree this is very annoying. Im going to post this question in the suspension forum and see if we can get an answer to this.
21 - 40 of 41 Posts
