Please help. Is there a climate control reset procedure for my 2014 Fusion SE (1.6L, FWD) with the My Ford Touch setup? With the A/C full blast, I have cold air blowing from passenger vents and warm air from drivers side vents. After much research, I replaced the air blend door actuator located above the gas pedal. Problem still exists. I see posts online about the need to now reset the climate control. All of the videos and descriptions I see are for other Ford models without the My Ford Touch setup. Is there a series of buttons to press in order for the climate control to reset the vent door stops to full open and close? Some different models show pressing the climate on button with the vent button, etc, etc.
Thanks so much, Doug
