1 - 9 of 9 Posts
As opposed to what, in glass? My Mazda6 has an in-glass antenna, which they used only on the '03's before switching to the high/center mount antenna in the '04's... the in-glass antennas have far worse reception, because you have metal and such blocking much of their "view." Higher end cars use multiple antenna's to get around this problem.
Yes, as opposed to the current in glass antenna (which is in the back glass). What did you think i meant, hold an aluminum pie pan out the window and hope to pick up a station. I also get great reception with the current set up, thus my question. It's not a big deal, I prefer to not have an exterior antenna for kids or parking lot dimwits to yank.
The in-glass antenna works great for me too.
What type of exterior antenna is Ford switching to? Mast or fin? I would imagine if it the mast then it is due to cost savings. If it is a fin then I would assume that it is for technology.
I have had no problems with the in-glass antenna until I noticed that on some FM stations (around 100.5) they fade out if you turn on the rear defroster. Apparently the rear defroster blanks the antenna when you have a weak FM station tuned in. Has anybody else tried this?
[quote author=bartman1 link=topic=54868.msg908067#msg908067 date=1156349501]
[glow=red,2,300]AH HA ![/glow]
maybe we now know the reason Ford is switching to a Mast antenna???
I haven't noticed this yet...
the Freestar we have has an antenna in the window, but its in the passenger rear quarter window, and thus no problem with defrost.
Yes in-glass antennas are inherently less effecient however some engineers (including the ones designing the fusion) take this into account and install FM boosters. If you look at a wiring diagram, the booster is clearly there (although not well labeled).
1 - 9 of 9 Posts
