1 - 10 of 10 Posts
I have a 07 Fusion SEL. I am having a hard time locating the BCM (Body Control Module) on my car. I just purchased HIDs for my car and its seems like if i were to turn them on while driving down the road they flicker and on my message control center it says "check right/left headlamp", whether its day or night. If i were to start my car at night and then turn the lights on normally they flicker also. Now if i turn on the lights first and then start my car the HIDs are fine, no flickering. I called Pilot HIDs and explained them that problem thinking it was just the company that i bought them from and its not. I was told all brand will do it. Your Daytime Running Lights are getting in the way. I need to disable them. I have two options.
1) Get into the computer and disable them throught there- called my local Ford dealer and they said they couldnt do it. DAMN!
2) Locate the BCM and cut one wire/cap and send other one to ground disabling it. Well i used to have a grand am gt and thats the way i disabled them. I just cant find the BCM and not really sure what wire is what. Has anyone attempted to do this or possibly knows where the BCM is? Or maybe knows how i can get an electrical diagram or schematic of my car? Any help or suggestions would be great.
Also, Has anyone had this same problem? I am not really finding anyone else with similar problems!
-RJ
Not currently no, I am sure with some time and work it can be found tho. Wasn't it located under the "glove" box on the pontiac?
Yea actually it was located right behind the glove box. I wasnt sure if its the same setup tho since its a different car. Whats a PDF?
Call up the dealer and see what they say. What is the worst they are going to do? Couldn't hurt right?
1 - 10 of 10 Posts
