1 - 9 of 9 Posts
I've got some bulbs here, all red.
I'm looking for $3 shipped for the pair of 7440 Incandescent red bulbs, $8 shipped for the pair of 7443 9-LED reds, and $7 shipped for each pair of 7440 9-LED reds.
Reply here or PM me for details if interested. Thank you!
I forgot to add, the incandescents have a pinkish-hue to them, which bugs me personally, but it may not bother others.
[quote author=rcrooks link=topic=72312.msg1274920#msg1274920 date=1174256716]
You need to get the resistors with these to slow down flashing right?
Yes, you need the 6 ohm for these, unless you have LEDs in the front as well, in which case you need 3 ohm (I believe).
7440's fit the turn signals, and 7443's fit the brake lights.
[quote author=saluteTOme link=topic=72312.msg1285286#msg1285286 date=1174612509]
you need the resistor for the brake lights?
Nope, only for the LED turn signals.
did you try the 7443's in the stock tail light/brake light housing? Did they reflect OK, or do they simply shine straight out? I am on 2nd set of LED's and none work properly... so I am still looking.
Thanks
Igor
[quote author=igor2 link=topic=72312.msg1287767#msg1287767 date=1174710783]
Thanks
Igor
They light up the whole housing, but not as bright as the stock incandescent bulb. I may be able to make a small video if you like, as in DRLs then brakes applied.
1 - 9 of 9 Posts
