[quote author=basstoy link=topic=148095.msg3185992#msg3185992 date=1245378123]
I knew I was just gonna get a reply like this.. I know all that... it does get cold.... but my dads 01 pt criuser gets so cold my nipples could cut ice... and I know its not leaking cuse my car has the florescent crap in it anyways from factory.(I checked)..and I looked in the dark with a black light , I just wanna knowhow I would just add a bit more refrigerant, just to see... there are no "L" or "H" on the black caps just one near the firewall and one near the headlight....
Well basstoy, you are very welcome. :eek4:
Sorry you did not like my reply. Or, as you so eloquently put it "I knew I was just gonna get a reply like this...". Unfortunately, whether you like it or not my reply directed you to follow the correct course of action to properly repair your A/C system.
Has it occurred to you that perhaps you do not "know all that" and should listen to helpful advice when it is offered? Or at least be a bit more polite to someone who was polite to you?
I am curious: How do you think your A/C systems refrigerant managed to be under pressurized in the first place (if that is the problem)? If you are correct and your system is in need of a "recharge", then it has a leak. The refrigerant did not magically disappear.
You can not just "recharge it" without the proper tools. So I will leave it up to someone else to direct you in how to damage your A/C system.
Just as an FYI: If you did not like my advice, you could have simply ignored it, or politely stated that you understood what I was saying, but would still like to try and recharge it on your own anyway. That would have been the polite thing to do and I would have had no complaints.
Good luck. :cheers:
