1 - 20 of 62 Posts
...... a 1978 Ford Fiesta!!! :pokey:
We pulled it from inside a barn where the goats used it as a mattress. haha :lol:
It's a 1.6L four cylinder with a 4 speed.
Get this, it cranked right up. The last inspection sticker says 1986.
My brother and I are going to get it road worthy, repair the rust, give it a paint job..and sell it for 100% profit since we got it for FREE...or maybe drive it around since gas is $3.50 a gallon!!
That is actually considered to be a classic automobile. Fix her up a bit and make a few coins. :icspot:
[quote author=Canadian_LX link=topic=187231.msg3952222#msg3952222 date=1299252778]
How do you plan on getting the goat smell out!? :shock:
They were only on the outside of the car, they couldn't get to the interior. And we just sprayed the whole car with Purple Power and used brushes to get all the "ick" off....
Discussion Starter · #11 ·
So wow, dug into the Fiesta over the weekend. The weirdest Ford ever....this is basically a VW Rabbit in Ford clothing.
We were trying to get the brakes to work. No pressure on the pedal but the rod engages in the master cylinder. Wouldn't there be pressure if the lines were clogged???? By the way, this thing has front discs that are like 6 inches in diameter!!!! so small. It also uses lug bolts as there is no "stud" to put a lug nut on. It's all one piece.
It has air conditioning too haha. Doubt we can get some C-2 refrigerant which is what it calls for, wow outlawed long time ago I am sure. Besides the rust (plenty of it), no brakes and no refrigerant....it runs and works beautifully!
12 inch dubs on it too!
Discussion Starter · #20 ·
Ok, worked all day Friday on the Fiesta. Got the Front pads to semi-engage. Took the rear drums off. Driver rear has a busted wheel cylinder so there was the no brake pressure culprit. The bolts on the backing plate holding the wheel cylinder were basically a part of the backing plate they were so rusted. Got them out finally in tact too, but the brake line nut was destroyed, but thats an easy fix.
The real problem is that a drum return spring was broken and the brakes shoes were laying in the drum. The shoes are available, but the drum spring kit is OBSOLETE. None of the parts stores have them, zip zilch N/A.....this is a problem. Local junkyards have NO Fiesta's either. We even looked up parts for a 78 Rabbit and 81 Escort, the springs are different lengths!! :(
I know that there a lot of Fiesta's still on the road/being fixed up in Europe, so where are they getting their parts????? I need help fellow FFC'ers cause this will put a serious kink in getting it on the road so we can enjoy the 47 mpg's that were advertised for this car back in the day....
1 - 20 of 62 Posts
