I've been doing some research on the MRT T-5 Fusion put on display at sema. It looks like the T-5 Tremec is what was used on the awd setup to make it a 5 speed manual, I wonder how easy it would be to do this swap. It does have an adjustable shift track so that wouldn't be a problem. I'd just like to see what you all think about it. If this is a repost sorry for that I looked around and didn'rt find anything on the t-5.
Oooo..lets play stump the swammies...good question Mason.
The MRT Fusion is NOT a manual, it's automatic. The T-5 trans can't be used on the Fusion because it is not a tranverse set up. You would have to remount the engine and re-do the whole wiring harness, etc to run a t-5. They call it a T-5 Fusion cuz they're running a T-5 turbocharger, not a T-5 trans.
http://www.cardomain.com/ride/2578339
Note the third pic, (interior shot) auto-shifter.
The T is for turbo and the 5 is for 5 Speed Automatic :dur: I was way off, but it makes you wonder what auto 5 speed did they use and what are the ratios for it. This is from edmunds for the 06 that they discussed I didn't even realize that they brought another in 07:
"Think "real world." That's what the MRT Fusion is all about. Cranking out a fat but reasonable 325 horsepower, MRT left the engine completely stock and integrated a Garrett T31 turbo and front-mount air-to-air intercooler into the Fusion without any permanent alterations to the car itself. Even the stock exhaust manifolds and catalysts are retained. Off-boost torque remains exactly as stock, and it shouldn't have any trouble passing an emissions test."
it says what turbo was used in this on
http://www.edmunds.com/insideline/do/AutoshowArticles/articleId=117378
and here's where it says the designation meaning.
http://www.topspeed.com/cars/ford/ford-fusion-t5-by-mrt-ar15039.html
