not my post but maybe this will help. It is basically 2 adapters that hook up to your factory radio to be able to use external MP3 players. You also dont loose your steering wheel controls. Again hope it helps.
Forum Member
WWW
Re: Aux RCA Input on CD/6 CD Player
« Reply #13 on: September 04, 2006, 04:41:55 PM »
AUX INPUT (RCA IN):
Here is what you need:
http://www.discountcarstereo.com/detail.aspx?ID=973
http://www.discountcarstereo.com/detail.aspx?ID=971
This allows for aux input into the back of your 6 disc premium. When following the instructions, please note that the dip switch settings are incorrect. Turn on switches 1, 2, and 3. After that hook all the cables up and you are set to have aux audio coming into your stereo. Very handy for all the useres without ipods or any other type of audio that you want to bring into your stereo.
If you have an ipod and you want to charge it you can get one of these:
http://www.sik.com/imp.php
This allows line levels out so you dont use the click wheel to adjust the volume, and allows you to charge your ipod at the same time. It connects through the dock connector for audio out and charging.
RCA OUT:
Just get a line level out converter. it goes from speaker level out and converts to line level out (RCA). This works great for installing amps.
EDIT: I saw people were tlaking about two different things so i put rca in and rca out for clarification.
