What models are interchangeable with 2012 fusion
Hi Donald. The 2010-2012 Fusion is the mid-cycle refresh of the 1st generation Fusion. So almost all 2010-2012 Fusion parts are "interchangeable". Many mechanical pieces from the 2010-2012 Mercury Milan are also "interchangeable".What models are interchangeable with 2012 fusion
Is it possible to swap a 2009 ford fusion front bumper and lights with a 2010 ford fusion?Hi Donald. The 2010-2012 Fusion is the mid-cycle refresh of the 1st generation Fusion. So almost all 2010-2012 Fusion parts are "interchangeable". Many mechanical pieces from the 2010-2012 Mercury Milan are also "interchangeable".
Some parts from the 2006-2009 Fusion (and Mercury Milan) are also "interchangeable", but that will be on a case by case basis according to part.
All of that being said, always purchase by part number. If the part is the same, the part number will be the same.
There would probably way too much other stuff that would need swapped in order to use the bumper cover and headlights. Fenders, grille, hood, radiator support, and even then not sure they would bolt on.Is it possible to swap a 2009 ford fusion front bumper and lights with a 2010 ford fusion?
Hi Soldier71 and welcome tot he Ford Fusion Club. What bangster stated is correct. You would also need to replace the front fenders, hood, etc. etc.Is it possible to swap a 2009 ford fusion front bumper and lights with a 2010 ford fusion?
