DISCLAIMER: The measurements listed here are what I have used successfully two times. Note that all cars are not created exactly the same so my measurements may be slightly different than your actual measurements. This thread is to be used as a guideline or reference and not as an exact science. Basically, take your time and MEASURE TWICE-CUT ONCE.
As you can see by the receipt my chrome bar part came in today..the part # is also shown for those of you who do not have it yet.
Below are the parts needed to complete the install. They are (2) brackets that are 2" x 2" long (2) 1/4" X 3/4" machine bolts with matching 1/4" lock washers and 1/4" nuts. I opted for stainless steel for its resistant properties to rust and corrosion. Also needed is a 1/8" and 1/4" metal drill bits along with (2) stainless steel 1/8" pop rivets.
Next you will need to remove approximately about 1/2" of material from the chrome bar. Very important to split the difference on each end of the bar (DO NOT TAKE THE WHOLE 1/2" OUT OF ONE SIDE) so the crease on each end of the bar will line up with the crease on the 2 bars that are already on the car. So take about 1/4" off each end as shown below.
Here it is after the cut..
Next, measure in 3 3/4" on each end and this is where you will attach the 2 x 2 brackets. Be sure to drill out one of the bottom holes on the bracket to 1/4" before installing the bracket onto the chrome piece. Using the hole closest to the bend in the bracket, line the edge of that hole up with the edge of the chrome piece at the 3 3/4" measurment and drill a 1/8" hole through both chrome piece and bracket and install the 1/8" pop rivet and secure as shown below..
Now is a good time to paint the bracket flat black to insure rust resistance...TAKE NOTICE OF THE SLIGHT OFFSET IN THE BRACKET..YOU MUST PUT THIS BEND IN YOUR BRACKET SO THE CHROME BAR WILL SET LEVEL WHEN INSTALLED.
Please notice the area below on both sides of your vehicle...
Place the chrome piece with the attached bracket up to the car to mark and then drill a 1/4" hole on the marks after making sure to equally space the bar on each end from the one above to keep the same distance between all three bars...
Here is what it will look like on each side after drilling the holes....
Now place the chrome piece back onto car and install the required mounting bolts and nuts shown in the above hardware picture...
Congratulations, now sit back and enjoy your handiwork!! Make sure to paint the exposed machine bolt head flat black for an un-noticeable bracket!!
Here's a shot with the 3dCarbon kit installed...
