1 - 20 of 61 Posts
Premium Member
Ok first let me say thanks to Seasonalskier. If it wasn't for him I would have never thought of doing this mod.
To do this mod you will need an led strip.
The ones I used, I bought at Pepboys awhile ago but ebay has them too.
This is an led strip I got for another mod. it will look just like this but a lot shorter. And you can get any color you wish.
They come with 3M adhesive. So all's you have to do is peel and stick.
Start by busting open the sidemarkers. I suggest getting a spare set so you don't rush things. This only took me about an hour to do but I left them to cure overnight.
Aftermarket sidemarkers (clear/smoked) are way easier to work with.
Start by scoring around the perimeter of sidemarker. Then get a small flathead screwdriver and start pry it apart. I recommend starting on top and working your way down.
Once you have them separated clean it really good so the adhesive will stick without any problems but don't stick it on just yet.
Now we need to figure out how to connect them to the stock connectors.
I took apart the connector and solder the wires to the prongs.
To take it apart grab your screwdriver and push the prongs in. Then pull out.
Once they're out, solder the wire to each of the prongs. If you can, check to see which is the positive and which is the ground on both your car and the led strip.
Once you got them put together go and check they light up. If they don't you'll need to switch the prongs around.
When you get them to work grab the sidemarker and feed the led strip through and secure the connector in place.
Now you can stick the strip down on the sidemarker. Where you put it exactly is up to you.
Then you'll need to seal the markers back together. I used windshield silicone. The same stuff I used on my taillamps. It works great.
Clamp the sidemarkers together and leave them overnight.
Final results
holy crap! that's soooo hawt!! :shock: i've got to do this! thanks Luis and Kenny, another summer project! haha!
so question, it's kind of hard to tell in the pics, but you removed the bulb, took apart the bulb harness, and soldered the leads from the led strip to the inside of the bulb harness?
Premium Member
Discussion Starter #4
Thanks guys. It was no problem at all. I'm a big fan of cheap mods.
JP, that's pretty much what I did. When you take out the bulb you'll see the prongs. You need to take them out to solder the wire leads. When you're finished with everything it should look like nothing was ever done to it. That way you only have to plug it back in.
Let me know if you need help with anything. That goes for everyone.
Can you take a night pic from far? Also, I stickied this in case you didn't notice. I'll def. be getting to this.
Premium Member
Discussion Starter #9
Yea I noticed earlier, Thanks biggee.
I'll get pics as soon as it gets dark. I'm sure if you have the flashing sidemarker mod it would still work.
Adam, go to ebay and type in "amber led strip" You'll find plenty to choose from.
Definitely going to do this. I love making the exterior of the car look different in some way/shape/form. This simple mod will be sweet to do. I'm going to assume a Soldering Iron and the necessary supplies are needed yes?
Premium Member
Discussion Starter #12
Thanks guys.
A soldering iron would be easier to work with. I used a mini torch but I've been soldering since I was 10. Either way I highly recommend soldering. I don't see any way around it.
Premium Member
Discussion Starter #17
Soon enough guys. I'm working on my lower grille. I need to take the bumper off again so I want to wait to put them in. I'm getting anxious to show you guys what I'm doing. Hopefully by next week.
Will these have the same problem a normal LED will have? there was some electrical thing you had to get if you put LED's in the sidemarkers. Are these just a simple swap?
Premium Member
Discussion Starter #20
Adam, for me it was plug in play. I don't have the flashing sidemarker mod. All's I had to do was plug it in and it worked.
I think you're thinking of the turn signals. You need resistors for those so they can flash. Maybe if you modded the sidemarkers you might need them too. I'll check later to see if they work or not.
1 - 20 of 61 Posts
