[quote author=fordfusion07 link=topic=75081.msg1347598#msg1347598 date=1176931616]
I have a 2007 Fusion SEL and I just purchased HIDs for my car from
www.hid.vg. My problem is that if i wanted to turn on my HIDs while driving down the road, my HIDs start to flicker. If I turn on my HIDs first then start my car and drive down the road they are fine. I dont want to drive around with my HIDs on during the day if i dont have to. I know this sounds very confusiong because trust me im lost. I called the company and explain to them the problem and they said i need to find the daytime running light fuse and pull it. Well the problem is that i cant find the fuse anywhere. Its not listed in the owners manual or anything. I dont understand why my lights work fine at night but they flicker when i want to turn them on during the day. Can anyone give my some input or help me accomplish this? I would great appreciate it!
Hi fordfusion07!
As to why they are flickering (if they are installed correctly and not defective), my educated guess would be it is due to the fact that the Daytime Running Lights operate at a lower power output than when the headlights are turned on. Therefore, your HID's are not receiving enough power to operate correctly when in DRL mode, and flickering. When you turn them on first, then start the car during daylight hours, they are receiving full power, and not flickering.
As to the correct fuse to disable the DRL's, I checked my manual (MKZ), and could not find a fuse labeled for the DRL's in there either. I am sure someone here has discovered the correct info, and will weigh in shortly. If not, you may need to ask the Service Manager at your Dealer for that info. I am sure they can provide that for you.
Good luck! :cheers:
