1 - 10 of 10 Posts
Ok so ive been told and have read the the DDM tuning HID kits are really good and are at a reasonable price. Now with that said I'm not to sure what to get with the kit, I know what bulb size and color I want i just dont know if I need the other goodies that can be added to the kit. I have a choice to add an HID harness and error eliminator but I'm not sure if I really need it or not. Thanks for the help.
Also I have a 2012 ford fusion of this helps.
Yes you will need a direct battery harness connection to stop the on and off flickering of the hid lights because the oem light harness from the car somehow doesnt produce enough energy for the HIDS. Yes you will also need a error eliminator to eliminate the annoying buzzing/humming sounds that you will start noticing .
I have a 2010 ford fusion shouldnt be much of a difference . Hope it helped
Discussion Starter #3
I really appreciate the help man i know what i need to get now but the only other thing is do i need the single relay or the dual relay harness?
dual is the best way just because if one fails at least you still have a headlight. the retrofit source has them for like $30 and they are really good quality. I have been running the same one for 2+ years no issues. They are also very water resistant which helps longevity.
Here is what I recommend, spend the $ now or spend it in replacements.....
Harness
http://www.theretrofitsource.com/components/harnesses/morimoto-h11-low-beam-relay-wire-harness.html
Canbus(error eliminator) you only need one, but they come in 2 packs... BACKUP!
http://www.theretrofitsource.com/components/harnesses/morimoto-standalone-canbus-wire-harness.html
Discussion Starter #5
Harness
Low Beam: H8/H9/H11 - Relay Harnesses from The Retrofit Source Inc
Can-Bus Standalone Error Cancelling Harnesses - Headlight Relay Wire Harnesses - The Retrofit Source
So then all i would need are these and then some HID bulbs huh? It dont seem that hard to piece this bad boy together then.
oh no you can get a kit thats fine, im a big fan of The Retro fit source, customer service and quality is really good. but you can get the DDM kits and the other 2 piece and they will all work together fine.
Definitely go with TRS. Top notch products, warranty, and customer service.
What I really recommend is doing a retrofit since the EVOX-R is a direct swap with the stock halogen projector.
Discussion Starter #10
If these don't work out I will look into the TRS ones, I really want to do a retro fit bad but sadly its a money and time issue at the moment.
1 - 10 of 10 Posts
