Just bought these LED bulbs from AUXITO to replace the headlight bulbs. I expected some difficulty installing these as some cars are very difficult but my 2014 Ford Fusion was no problem at all. I had to remove two bolts on the cooling system overflow tank to lift it out of the way on the passenger side but then access was easy. Just be aware the size of the base of the bulbs, they may be a tight fit in the housing of you vehicle. I'm seeing much more of the road now with these lights, matches the look of my fusion perfectly. I got the H11 for my low beams and fog lights.
