Headlight flicker ford fusion
2135 Views 3 Replies 3 Participants Last post by  hbmboratto
2014 Ford fusion
Hi
I got new led headlights (auxobeam f3 canbus). My led headlights(low beam,high beam) flickers when i use turn signals
I checked switches,alternator, battery change... Nothing wrong with those
I had hid kit before
recently i changed to led headlights.. Now i have the problem even on halogen
Flickers only with ignition on
Is it possible that i broke BCM?(resistor or mosfets)
2014 Ford fusion
Hi
Hi Bobinor and welcome to the Ford Fusion Club. Unfortunately yes, if you still get flickering after reinstalling the halogen bulbs, there is probably damage to the lighting/electrical system.
Normally troubleshooting (and overall advice) would be to reinstall the halogen bulbs. However, since you already did that and the problem is still present, further troubleshooting will need to be performed by a shop, unless you have the tools to do it.
  • Like
Reactions: 1
Normal troubleshooting (and overall advice) would be to reinstall the halogen bulbs. However, since you already did that and the problem is still present, further troubleshooting will need to be performed by a shop, unless you have the tools to do it.
Thanks for reply
I will let you know
Cheers everyone! Is there any news about this topic? I have a 2014 ford fusion ecoboost in Brazil, I have the exact same problem. I've installed led bulbs on the low beams that flickers when use turn signals. I installed my halogen bulbs again and noticed the flickering still exists, but almost can't notice the flicker with them. Probably because de LED have instant bright when turned on. In my perception, the car always had this flickering problem but never noticed on the halogen bulbs. Is there any way to solve this to get nice working LEDs?
