i had arctic whites in my focus, Its not white, its blue, the output sucks cause the bulb is way too filltered. I have Cosmic whites on the way today. which from what im told is much whiter than silverstars which suck. mine only lasted 6months.
Be careful on wattage. either choose stock wattage stage 1s or stage 2s are high wattage and is highly recomended that you get a hd headlight harness like a kyo, to prevent your stock connector from melting. there is also a chance that you can melt or discolor your chrome reflecters in your headlight due to heat, if using stage 2s, but i dont have that issue. USE AT YOUR OWN RISK.
the nokya bulbs say a certain wattage on the package like a stage 2 would say 100/90 but it only uses 80/70 watts high/ low beam. it uses lower wattage but light output is that of 100/90 watts. stage ones use factory wattage but the output is 20watts higher.
