When you put the key in the run position but don't start the car, what lights stay on? My oil, engine, and charging system lights stay on the whole time the key is in the run position but go away after the car has been started. Just wanted to know if other fusions lights stay on in run too. Also my message center tells me in run position to check charging system but goes away after the car has been started. I ran a system check off the setup menu it comes back ok when car is started but tells me to check charging system off that same system check when car is just in run position. Why the diffrence?
