[quote author=Ferendon link=topic=143579.msg3094492#msg3094492 date=1241104996]
The brief answer is that batteries create electricity through chemical reaction. They have several million joules of potential energy. Capacitors only store electricity on their plates, and even a 10 farad cap is only capable of holding a couple hundred thousand joules (A fraction of what a battery has). By the time a capacitor is drained down to about 10v, the remaining power in it is no longer usable, even though it is still at roughly 50% of it energy potential, meaning you can only use about half of the 'juice' a cap can hold. Once that cap is discharged, something has to charge it. That being your alternator and battery. Capacitors also have ESR (Equivalent Series Resistance), which is essentially a measure of how much power a device uses, or turns into heat (wastes). That ESR is basically negative efficiency. You take power from your battery, use 5-10% of it, just in ESR, and the rest is stored in a capacitor, where only half of it is still accessible, before it reaches a voltage level that renders it useless. Now you've taken the power you had, thrown about half of it out the window, and used the rest; but your lights didn't dim! (This is where the illusion of caps being worth a crap comes from) One good battery up front will have far more capacitance, or reserve power, than a standard auto battery, without the extra cost of parts used to install a capacitor, and without introducing any new drains on the system. Another option is a second battery or power cell. Stinger makes a really small power cell call the SPV20, and there are many other available on the market for roughly $100. Installation of a second battery is identical to how you'd install a capacitor, except in some cases you need an isolator. With something small, like an SPV20, you wouldn't need an isolator, you'd spend about the same $$$ as you would for a capacitor, but you'd see 10x the results, and they'd be REAL results, not just a band-aid solution to make it appear as if your problem was fixed.
Thats good info to have. Especially since I was planning to add a cap. I guess I'll upgrade the battery instead. Who knew? :dunno:
