Anyone else have this problem with your window when it rolls up??
Mines so loud that it makes people walking by do a double take!
So far the dealer has replaced ALL the rubber in the door sill and I still get the LOUD squeel when the window is rolled up.
Here's the weird part, it only squeels when it's rolled up after about 20 or 30 seconds or longer.....as if your using a driveup ATM and after you're done you roll up the window.......if you roll it up and down right away it doesn't squeel???
Dealer now is stumped and will look for a TSB bullitin, with my luck there is none!
I just noticed this too 2 car washes ago.....and it's all of my windows now. It only happens when it goes up. Also, I'm getting all of these marks on the glass, like something is smearing when the window is raised or lowered. The good thing is it's gone when the car is washed. I wonder what's causing the squeaking though????
My driver window does this too but not all the time. I think its when its going up right at the last couple inches. I'm not sure .. its not been persistant so I've not really noticed it. My main thoughts were to worry a bit that something was rubbing too hard and being damaged, or that (like my corolla) it was binding and would keep getting worse until the window would not go up anymore.
well, after 5 trips and 3 actual attempts to fix (they had to order parts twice so I had to bring it back) they finally figured out the squeeking/screaching of the window was caused by the window regulator...they changed it last week and so far so good no more noise....BUT now the passenger side window is starting to do it...at least now we know what's wrong!
