1 - 12 of 12 Posts
home depot white abs plugs you need to of them,, remove symposer.... best to remove the hole intake manifold from boot pipe... remove the symposer.. the spring clip will be stuck to the rubber hose.. thats why best to remove it from the car... clean the are.. and T now, while its out of the car.. check for carbon on the valves.mine had almost none.. drop the abs plug into the hose were the symposer was.. clamp it off.. hose clamp is the best.. take hose from the firewall cut it to 3/ 4 inchs.. tap the other abs plug into it... put hose back on firewall..done,, you just saves between 45 and 75 $ happy now?
Packing materials Shipping box Health care Material property Box
Vehicle Car Hood Motor vehicle Automotive design
Hood Motor vehicle Automotive exterior Auto part Automotive design
Hood Automotive tire Motor vehicle Rim Carbon
Administrator
Sorry, I'm stupid. What does this do for the car and what size motor?
Hi ffj. I believe the OP is actually discussing removing the "Air Intake Resonator", but the language translation is a bit off. Take a look here for more information: Ford Fusion intake resonator - Google Search
There are even a few threads right here on the Ford Fusion Club which are contained in the Google results above.
Essentially, the short story would be don't do it.
EDITED: I seem to have been the one with the language barrier. ;)
The OP actually was discussing a "sound symposer" delete. Not the resonator delete.
why not? it just puts extra engine sound into the cabin.. i removed mine last week.. and nice and quite in the cabin.. and no harm to the engine or power
Administrator
Hi alfaromeoguy. The links I provided explain why it would be better not to.
But we are all free to do with our cars as we like.
Administrator
after 1 week installed,, the engine feels much smoother, and power onset is smoother also.. the turbo is more linear build up
Hi alfaromeoguy. It is only a part of a sound synthesizer. It may be quieter inside without it, since it essentially eliminates the synthesized engine sounds. However, blocking/capping it does nothing for engine smoothness, power, performance, turbo performance etc. etc.
Administrator
perhaps.. but my freinds whom have drivin the car also feel the same way.. anyway.. i am going back to my ecotec conversion into my 84 spider
Hi alfaromeoguy. I feel my car always runs, rides and feels better right after I wash it. And even better when I fully wash, wax and detail it. It feels great, but I know it is just a feeling.
Good luck with your 84 Spider!
1 - 12 of 12 Posts
