181 - 200 of 207 Posts
I have a question I currently have a 2008 fusion SEL with 20x7.5 wheels with a set of 225/35/20 tires they have had to been repaired due to a pothole (roads here in Denver are horrible) I was wanting to switch to 19" but unfortunately the are a lot more expensive. Is there a different tire I can run to give me a little bit more tread? Or should I just switch to 19"s so I can run a 40 series tire?
Hi I was wondering if the Cobra R rims I installed I took off my mustang will mess up my suspension and or tires there 17X9"s had a guy at the dealership said it mess up everything because of the offset any help would be appreciated
sweet this helped me alot i was gonna ask the question but then i found this thanks really big help
Help
I am about to order staggered rims but i want to make sure i get the rite size tires. the front rim size is 18x8 and 18x9 in the rear. i was going to go with a 225/40/18 and a 255/35/18? or a 225/45/18 and a 255/40/18. i dont want to rub. My fusion still sits on stock suspension. Any suggestions??? and i was also wondering about wheel spacers??? id like to be flush or as close as i can get without rubbing.
You will not rub unless you get crazy offsets. I run 18x8.5 just fine. Spacers will depend on the offset of the wheels (to make flush). Also, 225/40/18 and 255/35/18 are nearly identical to each other in overall diameter, I actually reverse stagger those sizes for the track (255s up front). How close to the stock 205/60/16? Not sure.
Just remember that wider rear wheels will make handling worsen at the limit (lots of understeer).
I have 18x8.5 wheels, all at +38 offset (evo x gsr wheels). Not sure what HPO is. I have very little clearance up front, however.....lots in back.
I've tried to calculate it but will a 19x8 with a +20 offset and 76 hub fit my 2008 fusion sel fwd? Going to be running a 225/40r19 tire
So are you guys saying that a 245/45/19 will work, without rubbing, but the speedometer (and MPG/Odometer) will be off by about 5 mph at 65? I've looked at some tire calculators and they're showing the difference between my stock 17's and these Mustang wheel/tire combos on Craigslist are about .8" wider and 1.82" taller, that's quite a bit.
I'm looking to only run these tires for a while until the rubber runs out, but I really like the 19" wheels. Then on the other hand, I'm scared to go with a 19" wheel because we have bad roads, and I don't want to deal with a bumpier ride. Anybody have any insight on this?
There don't seem to be many offerings in the 235/40/19 size :( Goes from grand touring to max performance summer. Would anyone know which tire would be the better way to go: 245/40/19 or 245/35/19? The O.E. tire diameter is 26.4", the 245/40 is about 26.7", the 245/35 is about 26"... I'm leaning towards picking up a set of 245/40 uhp all seasons(the Pirelli Nero's I had on the mustang I traded for the fusion was a great tire). Does anyone see any rubbing issues with this tire on a Titanium Awd? I know the speedo will be slightly off, but I can live with that.
I'm sure many would think "why not get a max perf summer tire?" I would think that would just be overkill, and the resulting lower tread life wouldn't be worth it...
Any suggestions would be welcome/helpful!
7 vrs 7.5 inch 17" wheels
My wife has lost to the pot holes of Michigan and I am looking for 2 new wheels.
Our 2006 Milan is AWD and it has 17 inch wheels. It seems there are both 7 inch and 7.5 inch wheels. Mine are 7.5 inch I think.
It seems the replacement wheels are most 7.0 inch. Will 7.0 inch work on this vehicle?
Why are there two different wheels so close in size?
Thanks
Is this information good for the 2013 models I own an se with factory 17s I believe. and in thinking about going 19 or 20s
Sent from AutoGuide.com Free App
Everything on the '13-'14 is different. I can tell you that the bolt pattern is now 108mm. The stock 18" wheels are 18x8, 55mm offset, 235/45-18 tires. The stock 19" tires are 235/40-19. I'm quite sure the wheels are 55mm offset as well. What fits? I have 245/45-18 tires on 18x8 40mm offset wheels on the '14 Fusion I just bought. They do stick out a little... I think an offset right around 50mm would be perfect.
New guy here with a question. ...will 225/45/19 fit 2011 fusion with no rub? I've been looking but can't seem to find an answer. .thanks
Looking at Discount Tire Direct's chart, they recommend a 225/40-19. If you use a 225/45-19 you're just increasing the diameter a very small amount over that. My guess is that they would be fine, since you're still using a rather skinny tire. Of course, you still need the right offset wheels, 35-40mm is about right for an '11.
Thanks 2010SEL I've been looking through out every post but couldn't find any info...I sort of thought they would fit since people are putting 20's on their fusions
It's been a while since I've been on here, I've been loving my Fusion! But now I'm at that point where I need to replace the tires, and I'm considering my options! I have the 19" rims, so as Im sure everyone knows the 235/40/19 tire choices are pretty limited :( So I got to thinking about what sizes I could use as replacements...I'm sure there may be a slight speedo difference, which I can deal with. What I'm wondering about is if I were to go with a 245/40/19 size, will there be rubbing issues, as well as will it even fit on the stock rims? I'm not going for a summer tire, want an uhp all season(Thinking about the Pirelli's) Any help would be very appreciated!! Is there anyone who has gone to a different 19" tire size on an 2013 Fusion awd?
