Has anyone tried to install their fog lights with a relay so they work with the low beams? Check this link.
http://www.accessconnect.com/fog_driving_lights_wiring.htm
My only concern is coming off the lead wire for the low beams instead of the negative side. I am concerned that the power will take the path of least resistance through the switch and the headlights won't turn on. Does anyone know if it matters if I come off the negative side of the lows instead? Thanks in advance for any help.
Re: Fog light install
Anybody out there? Well I hooked up the fog lights with the relay and an inside switch just like the diagram. Works great,only on w/lights and switchable, with one exception. Since the low beams stay on with the high beams the fog lights do not turn off when I switch on the highs. Anyone have any suggestions?
