The planets finally aligned...
We are working with Shift Marketing on their SEMA vehicles, (2) 2006 Zephyrs. Troy and I met at the dyno to thrash on their black Zephyr. I don't recall how many miles it has on it but I am sure it can't be much which means the HP and torque will only increase as the engine breaks in more.
The highlights:
- Their Zephyr is basically stock. The baseline and modified runs were both made with the inlet elbow in front of the airbox removed.
- The testing was done on a Dynojet 224.
- All numbers are SAE, temp was 83, humidity 51%
- All testing was done with premium fuel which means the baseline numbers are higher than what you would see with 87 octane.
Peak numbers were:
Stock FordChip
164.6 whp @ 5700 185.8 whp @ 6200 +21.2
162.2 ft/lbs. @ 5100 166.6 ft/lbs @ 5300 +4.4
Average numbers are approx.:
Stock FordChip
143.7 whp 177.0 whp +33.3
150.3 ft/lbs. 159.2 ft/lbs. +8.9
I am fairly pleased with the gains in HP but not sure what to make of the gains in torque. I'd like to get another on the dyno in the near future and work with some more changes for torque.
I'll have to defer to Troy for feedback on driving it now. I know from the previous vehicles we have done, plus the continued changes we develop that its a very nice kick. Between the power and the trans changes it ought to gain about .5s 0-60.
We have a long history of personally tuning 2.5L and 3.0L Duratecs in everything from Contours and Taurii to Escapes, 500s and Fusions... We will continue to work on the ETC 3.0Ls.
And yes as always we will continue to work on the I-4 stuff as well.
The highlights:
Peak numbers were:
Stock FordChip
Stock FordChip
